Ovládání vřetena přes RS485
18. 1. 2021, 5:14
Opět díky za tipy, vyzkouším..
18. 1. 2021, 8:19
zz912 píše: 18. 1. 2021, 2:09 Zapomněl jsem na all, tak to prosím zkus znovu:
Kód: Vybrat vše
tomas@debian-cnc-home:~$ sudo stty -F /dev/ttyUSB0 -a
[sudo] password for tomas:
speed 2400 baud; rows 0; columns 0; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>;
eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R;
werase = ^W; lnext = ^V; flush = ^O; min = 0; time = 0;
-parenb -parodd cs8 -hupcl cstopb cread clocal -crtscts
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff
-iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon -iexten -echo -echoe -echok -echonl -noflsh -xcase -tostop -echoprt
echoctl echoke
18. 1. 2021, 9:36
cat /dev/ttyUSB0 (i sudo cat /dev/ttyUSB0) mlčí :(
Zkoušel jsem i screen a tail (vykoukáno na SO), také nic.
Ještě jsem zkusil tyto dvě věci, jestli je to k něčemu:
Kód: Vybrat vše
tomas@debian-cnc-home:~$ ls -l /dev/ttyUSB0
crw-rw---T 1 root dialout 188, 0 Jan 18 22:14 /dev/ttyUSB0
Kód: Vybrat vše
tomas@debian-cnc-home:~$ sudo udevadm info -a -n /dev/ttyUSB0
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.0/ttyUSB0/tty/ttyUSB0':
    KERNEL=="ttyUSB0"
    SUBSYSTEM=="tty"
    DRIVER==""
  looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.0/ttyUSB0':
    KERNELS=="ttyUSB0"
    SUBSYSTEMS=="usb-serial"
    DRIVERS=="ch341-uart"
    ATTRS{port_number}=="0"
  looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.0':
    KERNELS=="2-1.7:1.0"
    SUBSYSTEMS=="usb"
    DRIVERS=="ch341"
    ATTRS{bInterfaceClass}=="ff"
    ATTRS{bInterfaceSubClass}=="01"
    ATTRS{bInterfaceProtocol}=="02"
    ATTRS{bNumEndpoints}=="03"
    ATTRS{supports_autosuspend}=="1"
    ATTRS{bAlternateSetting}==" 0"
    ATTRS{bInterfaceNumber}=="00"
  looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7':
    KERNELS=="2-1.7"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceSubClass}=="00"
    ATTRS{bDeviceProtocol}=="00"
    ATTRS{devpath}=="1.7"
    ATTRS{idVendor}=="1a86"
    ATTRS{speed}=="12"
    ATTRS{bNumInterfaces}==" 1"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bMaxPacketSize0}=="8"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="3"
    ATTRS{configuration}==""
    ATTRS{bMaxPower}==" 96mA"
    ATTRS{authorized}=="1"
    ATTRS{bmAttributes}=="80"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{maxchild}=="0"
    ATTRS{bcdDevice}=="0254"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{quirks}=="0x0"
    ATTRS{version}==" 1.10"
    ATTRS{urbnum}=="40"
    ATTRS{removable}=="unknown"
    ATTRS{idProduct}=="7523"
    ATTRS{bDeviceClass}=="ff"
    ATTRS{product}=="USB2.0-Serial"
  looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-1':
    KERNELS=="2-1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceProtocol}=="01"
    ATTRS{devpath}=="1"
    ATTRS{idVendor}=="8087"
    ATTRS{speed}=="480"
    ATTRS{bMaxPacketSize0}=="64"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="2"
    ATTRS{bMaxPower}=="  0mA"
    ATTRS{bmAttributes}=="e0"
    ATTRS{maxchild}=="8"
    ATTRS{bcdDevice}=="0000"
    ATTRS{version}==" 2.00"
    ATTRS{urbnum}=="35"
    ATTRS{idProduct}=="0020"
    ATTRS{bDeviceClass}=="09"
  looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2':
    KERNELS=="usb2"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{devpath}=="0"
    ATTRS{idVendor}=="1d6b"
    ATTRS{speed}=="480"
    ATTRS{authorized_default}=="1"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="1"
    ATTRS{maxchild}=="3"
    ATTRS{bcdDevice}=="0304"
    ATTRS{serial}=="0000:00:1d.0"
    ATTRS{urbnum}=="26"
    ATTRS{manufacturer}=="Linux 3.4-9-rtai-686-pae ehci_hcd"
    ATTRS{idProduct}=="0002"
    ATTRS{product}=="EHCI Host Controller"
  looking at parent device '/devices/pci0000:00/0000:00:1d.0':
    KERNELS=="0000:00:1d.0"
    SUBSYSTEMS=="pci"
    DRIVERS=="ehci_hcd"
    ATTRS{irq}=="20"
    ATTRS{subsystem_vendor}=="0x103c"
    ATTRS{broken_parity_status}=="0"
    ATTRS{class}=="0x0c0320"
    ATTRS{companion}==""
    ATTRS{consistent_dma_mask_bits}=="32"
    ATTRS{dma_mask_bits}=="32"
    ATTRS{local_cpus}=="ff"
    ATTRS{device}=="0x3b34"
    ATTRS{uframe_periodic_max}=="100"
    ATTRS{enable}=="1"
    ATTRS{msi_bus}==""
    ATTRS{local_cpulist}=="0-7"
    ATTRS{vendor}=="0x8086"
    ATTRS{subsystem_device}=="0x304a"
  looking at parent device '/devices/pci0000:00':
    KERNELS=="pci0000:00"
    SUBSYSTEMS==""
    DRIVERS==""
Ale počítám, že pokud by to bylo něco kolem práv, program by mi to řekl.
Ve Windows to stále funguje, tak jsem to snad aspoň zatím neodpálil :roll:
T.
18. 1. 2021, 9:56
Tady měl kdosi podobný problém (levný xx340 dongle, modbus rtu, windows ano, linux ne), vyřešil ho výměnou dongle:
https://stackoverflow.com/questions/456 ... nt-respond
Ne, že bych to takto chtěl řešit já, ale asi nejsem s tímto problémem sám.
18. 1. 2021, 10:29
No jen pripominam stranku 2 tohohle vlakna :lol: Ale drzim palec, abys to uchodil :!:
18. 1. 2021, 10:31
Zdravim z "LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO" LiveCD, tady to funguje..
Kód: Vybrat vše
user@debian:~/Downloads$ sudo ./modpoll/linux_i386/modpoll -m rtu -a 1 -b 4800 -p none -s 2 -t 4:mod /dev/ttyUSB0
modpoll 3.9 - FieldTalk(tm) Modbus(R) Master Simulator
Copyright (c) 2002-2020 proconX Pty Ltd
Visit https://www.modbusdriver.com for Modbus libraries and tools.
Protocol configuration: Modbus RTU, FC3
Slave configuration...: address = 1, start reference = 1, count = 1
Communication.........: /dev/ttyUSB0, 4800, 8, 2, none, t/o 1.00 s, poll rate 1000 ms
Data type.............: 32-bit module 10000, output (holding) register table
-- Polling slave... (Ctrl-C to stop)
[1]: 500
[1]: 500
[1]: 500
[1]: 500
[1]: 500
^C
T.
EDIT: Jeste si tu neco odlozim:
Kód: Vybrat vše
user@debian:~$ ls -l /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 0 Jan 18 22:28 /dev/ttyUSB0
user@debian:~$ sudo udevadm info -a -n /dev/ttyUSB0
  looking at device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0':
    KERNEL=="ttyUSB0"
    SUBSYSTEM=="tty"
    DRIVER==""
  looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0':
    KERNELS=="ttyUSB0"
  looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0':
    KERNELS=="1-1.4:1.0"
    SUBSYSTEMS=="usb"
    DRIVERS=="ch341"
  looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4':
    KERNELS=="1-1.4"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{devpath}=="1.4"
    ATTRS{removable}=="removable"
    ATTRS{devnum}=="5"
    ATTRS{ltm_capable}=="no"
    ATTRS{rx_lanes}=="1"
    ATTRS{busnum}=="1"
    ATTRS{tx_lanes}=="1"
    ATTRS{bMaxPower}=="96mA"
    ATTRS{speed}=="12"
    ATTRS{urbnum}=="161"
  looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1/1-1':
    KERNELS=="1-1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{busnum}=="1"
    ATTRS{removable}=="fixed"
    ATTRS{devpath}=="1"
    ATTRS{speed}=="480"
    ATTRS{devnum}=="2"
    ATTRS{bMaxPower}=="0mA"
    ATTRS{urbnum}=="53"
    ATTRS{maxchild}=="6"
  looking at parent device '/devices/pci0000:00/0000:00:1a.0/usb1':
    KERNELS=="usb1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{devnum}=="1"
    ATTRS{bcdDevice}=="0419"
    ATTRS{speed}=="480"
    ATTRS{urbnum}=="26"
    ATTRS{devpath}=="0"
    ATTRS{interface_authorized_default}=="1"
    ATTRS{busnum}=="1"
    ATTRS{serial}=="0000:00:1a.0"
    ATTRS{manufacturer}=="Linux 4.19.0-11-rt-amd64 ehci_hcd"
  looking at parent device '/devices/pci0000:00/0000:00:1a.0':
    KERNELS=="0000:00:1a.0"
    SUBSYSTEMS=="pci"
    DRIVERS=="ehci-pci"
    ATTRS{numa_node}=="-1"
    ATTRS{revision}=="0x05"
    ATTRS{device}=="0x3b3c"
    ATTRS{driver_override}=="(null)"
    ATTRS{irq}=="20"
    ATTRS{local_cpulist}=="0-3"
    ATTRS{d3cold_allowed}=="1"
    ATTRS{enable}=="1"
    ATTRS{ari_enabled}=="0"
    ATTRS{msi_bus}=="1"
    ATTRS{local_cpus}=="0f"
    SUBSYSTEMS==""
    DRIVERS==""
user@debian:~$
dmesg.txt
(57.29 KiB) Staženo 241 x
zz912
19. 1. 2021, 7:04
Thomeeque píše: 18. 1. 2021, 10:31 Zdravim z "LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO" LiveCD, tady to funguje..
Mohu Tě poprosit opět o:
Kód: Vybrat vše
Zajímalo by mě, zda tu bude něco jinak.
LinuxCNC - MESA 7i96
zz912.webnode.cz
19. 1. 2021, 7:51
zz912 píše: 19. 1. 2021, 7:04
Kód: Vybrat vše
Jasne, to me taky mohlo napadnout.
Pred prvnim spustenim modpollu:
Kód: Vybrat vše
user@debian:~$ sudo stty -F /dev/ttyUSB0 -a
speed 9600 baud; rows 0; columns 0; line = 0;
werase = ^W; lnext = ^V; discard = ^O; min = 1; time = 0;
-parenb -parodd -cmspar cs8 hupcl -cstopb cread clocal -crtscts
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl ixon -ixoff
isig icanon iexten echo echoe echok -echonl -noflsh -xcase -tostop -echoprt
echoctl echoke -flusho -extproc
Po nem:
Kód: Vybrat vše
speed 4800 baud; rows 0; columns 0; line = 0;
werase = ^W; lnext = ^V; discard = ^O; min = 0; time = 0;
-parenb -parodd -cmspar cs8 -hupcl cstopb cread clocal -crtscts
user@debian:~$
Charon píše: 18. 1. 2021, 10:29 No jen pripominam stranku 2 tohohle vlakna :lol: Ale drzim palec, abys to uchodil :!:
Njn, uvidime, dik!
19. 1. 2021, 7:53
Kdybys měl cestu kolem, půjčil bych ti ten svůj, ale to asi není reálné, viď?
zz912
19. 1. 2021, 8:25
Tak jsem porovnal nastavení stty od Wheezy a od Busteru. Nic jsem nenašel.
Můžeš se mrknout ještě na verze stty ve Wheezy a Busteru?
Kód: Vybrat vše
stty --version
zz912.webnode.cz
19. 1. 2021, 8:27
Charon píše: 19. 1. 2021, 7:53 Kdybys měl cestu kolem, půjčil bych ti ten svůj, ale to asi není reálné, viď?
To bohužel ne. Mohl by si udělat pokus, ale není to úplně na 5 minut.. Konkrétně zkusit to v LiveCD http://www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso. Obnáší to stáhnout to ISO, dát ho na CD nebo fleshku, nabootovat do LiveCD, stáhnout, rozbalit a spustit https://www.modbusdriver.com/modpoll.html. Předtím bys musel ještě připojit nějaké modbus zařízení a rozchodit modpoll na stejném stroji v jiném systému, abys měl prověřený set parametrů.
Mám btw. ověřeno, že u mne to nefunguje ani v LiveCD mého systému, tj. není to tak, že bych měl nějak rozhozenou instalaci.
zz912 píše: 19. 1. 2021, 8:25 Můžeš se mrknout ještě na verze stty ve Wheezy a Busteru?
Kód: Vybrat vše
stty --version
Mrknu, napíšu..
EDIT1 - Booster:
Kód: Vybrat vše
user@debian:~$ sudo stty --version
stty (GNU coreutils) 8.30
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <https://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by David MacKenzie.
user@debian:~$
EDIT2 - Wheezy:
Kód: Vybrat vše
tomas@debian-cnc-home:~$ sudo stty --version
stty (GNU coreutils) 8.13
Copyright (C) 2011 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
Dík, T.
Naposledy upravil(a) Thomeeque dne 19. 1. 2021, 8:41, celkem upraveno 2 x.
19. 1. 2021, 8:30
Promin linux je pro me neprobadane uzemi :D
zz912
19. 1. 2021, 8:30
Mimochodem, co Tě drží ve Wheezy? Máš nějakou mašinku na LPT portu a potřebuješ RTAI ?
Zkus se mrknout na tohle:
https://stackoverflow.com/questions/282 ... o-run-sudo
zz912.webnode.cz
19. 1. 2021, 9:46
Včera jsem pro řešení téhle kauzy udělal u sebe základní přepoklady.
Tedy konkrétně udělal jsem to nejpracnější z celého řešení - našel jsem měnič (víc než 2 hodiny hledání :-( ), motor a 2 převodníky. A pak nadrátoval motor. Ten, co vymýšlel dostupnost svorkovnice musel být asi původně gynekolog.
Až budu mít dneska chvilku, tak ještě udělám kabel pro RS485 a zkusím to.
Ale pokud píšeš, že to na RT jede a na starém RTAI ne, tak možná bude stačit jen propojit 2 adaptéry. Mám to tak udělané na novém RT, a to samozřejmě jede. Tak to ještě jako rychlý pokus zkusím na RTAI.
Jenom zas musím najít nějaký disk s tím RTAI. Prostě řešení SW problémů = furt nějaké hledání.
19. 1. 2021, 9:59
Charon píše: 19. 1. 2021, 8:30 Promin linux je pro me neprobadane uzemi :D
Chápu, v pohodě :)
zz912 píše: 19. 1. 2021, 8:30 Mimochodem, co Tě drží ve Wheezy? Máš nějakou mašinku na LPT portu a potřebuješ RTAI ?
Přesně tak, booster měl neakceptovatelné latence.
zz912 píše: 19. 1. 2021, 8:30 Zkus se mrknout na tohle:
Na co přesně se tam mám zaměřit?
Jinak, booster má vyšší verzi stty (8.30 vs 8.13), ale nenašel jsem, jestli jí mohu dostat i na Wheezy.
Mex píše: 19. 1. 2021, 9:46 Včera jsem pro řešení téhle kauzy udělal u sebe základní přepoklady.
Jeden pobitevní: motor není na ladění modpollu potřeba :)
Mex píše: 19. 1. 2021, 9:46 Až budu mít dneska chvilku, tak ještě udělám kabel pro RS485 a zkusím to.
Ale pokud píšeš, že to na RT jede a na starém RTAI ne, tak možná bude stačit jen propojit 2 adaptéry...
Nerozumím ti, ale věřím ti :)
Díky moc! T.
