STMBL servo driver - open source projekt z DE
lubos
21. 2. 2016, 9:03
Já tak nějak čekám jak bude verze tištáku 3.4 pak do toho asi půjdu ale co jsem koukal naposledy tak tam ještě nebyla.
bronek999
22. 2. 2016, 9:38
verzia 3.4 je v adresari kicad. Eagle do buducna moc nechcu podporovat?
Verzia 3.4 bude pravdepodobne coskoro premenovana na 4.0
22. 2. 2016, 9:44
bronek999 píše:verzia 3.4 je v adresari kicad.
Akorát je to jednořádkový dummy soubor.
lubos
22. 2. 2016, 9:57
Aho
kicad mám nainstalovaný aprávě proto vím žetam ten tišták neni.
crinq
22. 2. 2016, 2:35
Hi,
i'm a bit busy with my day job right now.
The schematic will get some changes in the power supply section soon.
There is a mockup of the pcb in the git: https://github.com/rene-dev/stmbl/blob/ ... stmbl.scad" onclick="window.open(this.href);return false; (see lines 340 - 357 for single modules)
Nico
crinq
22. 1. 2017, 5:45
Hi,
the STMBL 4.0 prototype is working:
https://www.youtube.com/watch?v=DIg71IrnDLM" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=-E1o_5cFyto" onclick="window.open(this.href);return false;
Schematic:
https://github.com/rene-dev/stmbl/blob/ ... bl_4.0.pdf" onclick="window.open(this.href);return false;
PCB:
https://github.com/rene-dev/stmbl/blob/ ... .kicad_pcb" onclick="window.open(this.href);return false;
https://seafile.ist-wunderbar.com/f/967462b001/" onclick="window.open(this.href);return false;
https://seafile.ist-wunderbar.com/f/049651b717/" onclick="window.open(this.href);return false;
3D Model:
https://www.dropbox.com/s/mds3rerb9qzyc ... 8.png?dl=0" onclick="window.open(this.href);return false;
Code:
https://github.com/rene-dev/stmbl/tree/newstuff-v4" onclick="window.open(this.href);return false;
V3.3 driving a Manutec R15:
https://www.youtube.com/watch?v=KfJ4x4bL54U" onclick="window.open(this.href);return false;
STMBL 3.3 stack for the Manutec:
https://www.dropbox.com/s/35u2tpufer0ug ... 4.JPG?dl=0" onclick="window.open(this.href);return false;
Nico
lubos
31. 1. 2017, 8:12
Tak co , kdo do toho půjde?
Já bych si jeden na testování rád sestavil.
31. 1. 2017, 9:35
taky bych se pridal na test
crinq
1. 2. 2017, 10:31
Hi,
we will assemble a batch after testing.
Nico
K_73
1. 2. 2017, 11:36
Hi Nico, it sounds good. Do you have some idea about the price per unit?
crinq
1. 2. 2017, 12:53
Hi,
i think we can do <10€ for a blank pcb, <170€ for smt assembled pcb (tested) and +50€ for the tht parts + heatsink (not assembled).
But we have to check the BOM and see how much rework and testing is needed.
There are two bugs in 4.0 that are fixed on Github but untested.
If you want to build your own please wait for 4.1.
Nico
misil
1. 2. 2017, 3:28
zajimave, nejaka serva bez driveru bych doma nasel.
Ale tech 170Ecek uz je docela dost, za to uz se da skoro sehnat hotovej driver.
Chapu dobre, ze ten driver nepotrebuje zpetnou vazbu od enkoderu?
1. 2. 2017, 6:34
misil píše:Chapu dobre, ze ten driver nepotrebuje zpetnou vazbu od enkoderu?
Ne, nechápeš.
crinq píše:Hi,
Nico
Hey Nico,
is any of the previous prototypes on active duty on the real machine already?
Cheers, T.
misil
1. 2. 2017, 7:26
Mex píše:
Ne, nechápeš.
no, na videu to nevypada ze by kablik z enkoderu na motoru vedl do driveru - ale ok, kouknu na schema :)
Zpět na „Ostatní elektronika“
