Geopolymery - zkusenosti ?
Věda, technika a další na co se nenašla vhodnější kolonka.
RSSM
25. 8. 2013, 8:52
Ahoj vsem,
zaregistroval jsem ze par jedincu zminilo ze ma alespon nejake zkusenosti s geopolymery.
Myslim ze napr. QNX. V minulosti jsem s kolegy tvoril dalo by se rict plastiky, na ktere by podobny material mohl byt uzitecny, a samozrejme i mozna na konstrukci CNC masinek.
Po precteni nekolika dokumentu jako napr. v priloze me zajima primarne nekolik veci -
1) ma nekdo konkretni zkusenost s hotovym materialem, napr =
http://www.cluz.cz/?page=en,geopolymery" onclick="window.open(this.href);return false;
nebo nejakou materialove dostupnou recepturu ?
2) pevnost v tahu by mela byt AZ 1:2 vuci pevnosti v tlaku + pevnost AZ 160MPa = ca jako dobry polymerbeton, alespon postrehy ?
3) udajne nulove smrsteni ?
1. The structure of the geopolymers prepared on the basis of fly ashes is
predominantly of the AlQ4(4Si) type and SiQ4(4Al), SiQ4(2-3Al).
2. The geopolymer on the basis of fly ashes is a porous material. The porosity
of the geopolymers is very similar in the region of nano-pores regardless of
the conditions of their preparation. The geopolymers’ strength is affected
substantially by macro-pores (103 nm and more) formed in result of the air
entrained into the geopolymers; these may also be fly ash particles that
underwent only partial reaction. The presence of Ca-containing additives
(slag, gypsum) reduces considerably the porosity because of the co-existence
of the geopolymer phase with the C-S-H one.
3. A concrete can be prepared by using the geopolymer binder. No shrinkage
due to hydration (typical for the cement-based concretes) takes place in the
concrete. The ratio of the compressive strength to the tensile strength under
bending varies in the range of 10.0 : 5.5 (this ratio changes in the cementbased
concrete from 10:1.) to 10.):1.5). The strength values of the
geopolymer concrete increase in the long run.
4. Rheological properties of concretes differ from those of Portland cement.
5. The geopolymer concrete is resistant to the corrosive environments.
6. No transition phase with a different composition as this is typical for
concretes on the basis of Portland cement was found between the
geopolymers and the aggregate (reinforcement).
Geopoly_Poster_1.62_CD.pdf
(2.12 MiB) Staženo 852 x
Naposledy upravil(a) RSSM dne 26. 8. 2013, 8:56, celkem upraveno 1 x.
RSSM
26. 8. 2013, 8:55
Hola, hola ! nikdo nic ?
el_fuego333
27. 8. 2013, 8:34
Pred par rokmi som to trosku studoval na vlastnu past. Z toho, co viem, : vela vyhod - vysoka pevnost v tlaku, nizsia v ohybe a kruteni, nizke zmrastovanie pri polymerizacii. Problem pri "tradicnom viazani" roxormi je vysoka alkalickost -> korozivita, preto, ak viazat, treba zvazit material, dobra odolnost voci chemikaliam, teplotam, nizka rozpustnost a vyluhovatelnost.
cisty elektrarensky popolcek som neskusal, skusil som drt z porobetonovych tvarnic, ktore sa vyrabaju z popolceka. Vysledok bol velmi zaujimavy. Skusal som urobit poreznu strukturu podobnu porobetonu (stavebny ucel) - pri podobnej hmotnosti ako porobeton sa to tvrdostou a pevnostou vyrovnako komunistickemu panelakovemu betonu. Mal som v umysle z toho robit nieco do zahrady.
Kazdopadne zaujimavy material.
Bolo by dobre otestovat nejake mixtury, ako budu reagovat na vibracie. Tiez to zvazujem pre stavbu ramu na stroj, ale chce to najprv urobit tie testy.
Myslim, ze metakaolin+sodne vodne sklo je dobra cesta k pojivu. Ako plnivo precisteny piesok.
QNX
27. 8. 2013, 10:41
Koroze výztuhy není u GP problém. Geopolymery z CLUZ mám a používám, fungují dobře.
Oliver Rovný
2. 9. 2013, 8:13
Tento materiál ma veľmi zaujal, len nedávno som sa o jeho existencii dozvedel od užívateľa el_fuego333.
Ja som sa síce zameral na cementové betóny, z mojej zmesi som zatiaľ vyrobil lože frézky (viz. http://www.c-n-c.cz/viewtopic.php?f=15&t=7894). Tento druh spojiva mi nejako unikol, ale vyzerá to ako zaujímavá alternatíva k cementu. Zaujímali by ma hlavne pevnosti v tlaku a ťahu/lome. Ale tiež konzistencia čerstvej zmesi.
2 RSSM: Vďaka za článok!
QNX
3. 9. 2013, 12:05
Oliver Rovný: pevnost jsem neměřil, tak ti žádná konkrétní čísla napsat nemůžu, ale GP by měl být vysokopevnostní beton. Konzistence ......... hmm, tak to se bude popisovat těžko. Je to dost zvláštní materiál a hodně záleží na poměru složek a druhu plniva. Při současném vibrování to jde velice dobře odlévat. Při velkém naplnění a vhodném plnivu to jde i modelovat (většinou dost blbě, protože to má snahu téct). Na lože frézky by se to asi použít dalo.
el_fuego333
3. 9. 2013, 1:45
Poznate nejaky zroj metakaolinu. Nejak sa mi nedari ho zohnat.
Eventuelne praskovy Al2O3.
Diki moc!
picom
el_fuego333 píše: Eventuelne praskovy Al2O3.
Diki moc!
Nestačil by ti korund?
QNX
Metakaolín dodávají České lupkové závody. Al203 zase Karborundum Benátky (možná už se jmenují jinak, ale to si najdeš).
RSSM
Diky vsem za reakci, taky jsem se docetl ze vazba na vyztuhu je bez problemu.
QNX píše:Koroze výztuhy není u GP problém. Geopolymery z CLUZ mám a používám, fungují dobře.
QNX - a da se odhadnout smrstivost ? mas od CLUZU nejaky technicky list nebo tak ? ja nenasel nic, mozna se na ne obratim primo, co by stala tuna a tak.
RSSM
15. 9. 2013, 6:28
Takze baucis, cena = 4*cement, pevnost 90/12MPa, smrstivost sem se nedozvedel.
QNX
15. 9. 2013, 9:23
RSSM: Smrštivost si už nepamatuju, ale byla malá. Zavolej si do CLUZ a chtěj pana Roubíčka .........ochotný pán, který tam má na starost geopolymery a on ti to řekne z hlavy.
Ředitel pro vědu a výzkum
Ing. Pavel Roubíček
+420 313 572 218, +420 313 332 247
roubicek@cluz.cz
Jo a ten technický list ......... něco mám, ale moc informací tam není. Musím to najít.
15. 9. 2013, 10:06
Ono to s tím smrštěním není tak jednoduché. Např. německý Nanodur má má asi 0,25 mm/metr. Ovšem za předpokladu, že bude přesně dodržena receptura. Musí se počítat i s vlhkostí štěrku a podle toho dávkovat vodu. Pokud se to nenechá uměle "stárnout", tak to tuším "pochoduje" asi tři týdny měřitelně.
RSSM
30. 9. 2013, 7:51
Jj, ja taky dostal technicky list, ale jak rikas - lepsi jak dratem do oka, zitra zkusim vyzvedet tu smrstivost.
Baucis.zip
(649.94 KiB) Staženo 538 x
RSSM
15. 11. 2013, 8:07
Tak smrstivost je pry pri pouziti pisku a klasickeho kameniva a dodrzeni postupu cca 0.15mm/m, verte neverte :)
Zpět na „Multioborová diskuze o technických tématech“
