Cincinnati ARROW 500
r4cv
8. 10. 2017, 7:10
tak si skúsim spraviť ešte jednu konfiguráciu a tam to skúsim.
BTW. ktoré súbory treba zálohovať, ak chcem spraviť zálohu súčasnej konfigurácie na USB kľúč? stačí INI a HAL?
8. 10. 2017, 7:12
vpodstate ano
pak jsou nejake tabulky nastroju atd..
na tom to nestoji
r4cv
9. 10. 2017, 4:56
Tak som skúsil gmoccapy a nejde.
chýbajú mu nejaké súbory, ktoré by tam ale mali byť (ver.2.7)
Keď spustím Pncconf wizzard, tak mi ani gmoccapy neponúkne. Mám zlú verziu inštalačky?
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/cnc/linuxcnc/configs/ARROW'
Machine configuration file is 'ARROW.ini'
INIFILE=/home/cnc/linuxcnc/configs/ARROW/ARROW.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./ARROW.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: gmoccapy
command (EMC_TASK_PLAN_PAUSE) cannot be executed until the machine is out of E-stop and turned on
Unexpected realtime delay: check dmesg for details.
Invalid on color value: greeen
**** GMOCCAPY GETINIINFO ****
Preference file path: /home/cnc/linuxcnc/configs/ARROW/ARROW.pref
**** GMOCCAPY INFO ****
**** No gmoccapy2.glade file present ****
**** Invalid embeded tab configuration ****
**** No tabs will be added! ****
**** audio available! ****
**** No virtual keyboard installed, we checked for <onboard> and <matchbox-keyboard>.
**** no valid probe config in INI File ****
**** disabled tool measurement ****
**** GMOCCAPY INFO: Gcode.lang found ****
**** GMOCCAPY INFO : inifile = /home/cnc/linuxcnc/configs/ARROW/ARROW.ini ****:
**** GMOCCAPY INFO : postgui halfile = postgui_call_list.hal ****:
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=5038
Killing task milltask, PID=5106
task: 124 cycles, min=0.000008, max=0.011983, avg=0.009277, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
/usr/bin/gmoccapy:240: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
(gmoccapy:5109): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
pyvcp_options.hal:11: Pin 'pyvcp.spindle-speed' does not exist
5038
PID TTY STAT TIME COMMAND
5106
Stopping realtime threads
Unloading hal components
Kernel message information:......
celé sa to nezmestilo.
9. 10. 2017, 6:12
Nechybi nic zasadniho jestli dobre koukam
Prez todle se to nedostane
Nemas tam pyvcp panel proto to nemuze nalinkovat signal
r4cv
9. 10. 2017, 7:30
Našiel som to v Hal súbore, zamriežkoval a už to ide.
Samozrejme zobrazenie otáčok vretena teraz nefunguje.
Na prvé pozretie ma zaskočila absencia rýchleho ovládania pohybov pomocou šípok a Pg up a Pg dn.
Treba to len nejako nastaviť? alebo priamo z klávesnice to nepôjde?
nechcem packať mastnou rukavicou po displeji. a tie presuny pomocou klávesnice sú rýchlejšie ako cez displej.
9. 10. 2017, 7:41
To jde nastavit
r4cv
9. 10. 2017, 8:36
Aj mi napovieš kde? gmoccapy.py?
10. 10. 2017, 4:56
Z hlavy nevim
je tam funkce keyboard shortcuts
r4cv
15. 10. 2017, 7:57
pomaly na prehrýzam gmoccapy fórom
https://forum.linuxcnc.org/gmoccapy?start=40
Mám staršiu verziu LinuxCNC (2.7.0) Je šanca tam nejako dostať najnovšie Gmoccapy? To by už malo byť lepšie nastavené, ako moje súčasné.
Všade je len postup sitahnuť nové ISO a nainštalovať nový LinuxCNC. ALebo mi niečo uniká?
zatiaľ mi ide o klávesové skratky, ale je tam vyriešených viac problémov, tak by tá najnovšia verzia bola fajn.
16. 10. 2017, 6:19
Asi by to bylo zbytecne komplikovane
Uloz si konfiguraci linuxcnc a udelej upgrade vseho
r4cv
18. 10. 2017, 6:17
Som linuxový kripel.
Hodinu som čumel do bedne.
Nastaviť Synaptic Package Manager bolo relatívne jednoduché, ale zistiť, že potom treba ešte spustiť aktualizáciu, na to som prišiel len náhodou.
V každom prípade úspešná aktualizácia je za mnou, mám teraz verziu 2.7.11, ale gmoccapy ostalo na verzii 1.5.8. Takže som problém s upgrade gmoccapy nevyriešil. Poradí nejaký linuxák? alebo ostáva nová inštalácia nového Linuxu?
r4cv
3. 11. 2017, 8:39
Po dlhšej dobe som sa dostal ku frézovaniu a zo stavu stroja zase vyplynulo zopár otázok.
1. Chladenie
Emulzia - na chladenie mám použité čerpadlo klasické čssr (asi 3COA?) občas mám pocit, že by to chcelo väčší prietok. Existuje nejaká rozumná varianta týchto čerpadiel, ktorá má väčší výkon/prietok?
priamo pri vretene mám 2 kĺbové hadice 3/8" s dýzou asi 6mm.
pomôže, ak dám hadičky 4 s menšou dýzou? Viac ich chcem, lebo často je nástroj v zákryte a emulzia sa k nástroju nedostane.
Vzduch - zatiaľ nevyužívam, ale pri obrábaní nasucho by sa mi hodilo odfukovanie špon. K dispozícii mám kĺbové hadičky s dýzou cca 3mm.
Zvažujem vyrobiť prípadne okolo vretena rampu, kde budú asi 4 hadičky smerovať do osi vretena. A cez jednu rampu viem poslať vzduch aj emulziu, každé zvlášť, prípadne aj spolu.
Je to blbosť?
EDIT: pôvodné čerpadlo mám motor 3kW, to nechcem používať kvôli spotrebe elektriny, som limitovaný.
2. Tlakový vzduch
na stroji treba vzduch na
-chladenie, ofukovanie nástroja - vzduch asi bez úpravy
-uvoľnenie nástroja
-ofuk pohonu zásobníku nástrojov
-odbrzdenie 4-tej osy
-ručné ofukovanie stroja podľa potreby
Podľa nejakých štandardov by som mal mať na vstupe vypínač, regulátor tlaku, odkalovač, nejaký snímač tlaku. (mám aj elektrický ventil na zapnutie vzduchu ak zapnem stroj a pomalý nábeh tlaku vzduchu) Toto všetko je integrované do jednotky úpravy vzduchu.
Je treba mať tento vzduch primazávaný?
3. Výmena nástroja
na stroji bolo pôvodne chladenie stredom nástroja. Cez rotačný prívod chladiacej kvapaliny do vretena sa púšťal aj vzduch na ofuk dutiny pri výmene nástroja.
Tento prívod nemám, na stroji nebol. Viem si vyrobiť prívod, ktorý by bol schopný fúkať vzduch do dutiny v prípade vytlačenej upínacej pružiny. - Vypínací valec by dotlačil sedlo do protikusu na vretene, aby tesnilo. Inak to bude voľne otočné bez dotyku. Treba ofuk dutiny? akým tlakom?
r4cv
7. 11. 2017, 5:00
r4cv píše:gmoccapy na verzii 1.5.8.
Po rade "use keybord shortcuts" som gmoccapy rozchodil a je to iná liga ako axis.
Keď si na to trochu zvyknem, tak to bude super.
r4cv
27. 1. 2018, 7:23
Postupne si zvykám na nové ovládanie. Určite ho môžem odporučiť, je to veľký posun vpred.
Včera sa mi ale stala nejaká nehoda. Neviem ako a prečo k tomu došlo.
pustil som program. Zarovnal som čelo a napadlo mi, že som zabudol niečo skontrolovať. dal som stop (asi tlačidlo na paneli)
skontroloval som to a dal som štart. Nepamätám si, či na displeji alebo panel, ale frézka namiesto toho, aby začala program od začiatku, pokračovala od aktuálneho riadku.
Samozrejme nebolo zapnuté vreteno a nástroj to švihol rovno do plného materiálu. No čo, zas budem potrebovať frézy... :(
Možno som spravil nejakú chybu v ovládaní, alebo som použil postupnosť, na ktorú autor nemyslel. Budem musieť dávať pozor, či sa to zopakuje.
r4cv
26. 5. 2018, 10:02
A mám problém....
po nabehaní cca 200 hodín na vretene sa začali prejavovať neduhy v pohonoch. Aby som bol presný, hlavne v osi Y. Prejavuje sa to hlavne pri dlhšej práci a väčšom zaťažení od obrábania.
motor je kolmorgen, pôvodný zo stroja:
menič ku nemu je od kolmorgenu AKD:
s nastavením mi pomáhal aj technik od TG drives, dne suž tuším, že nie je celkom správne. Ale od motorov neboli takmer žiadne údaje, tak sme to "nejak" rozchodili. Menič je ovládaný kartou 7i76 v režime STEP-DIR, tj nemám spätnú väzbu do systému o skutočnej polohe (súvisí to z otázkou 3)
dnes som frézoval z bloku ocele 11523, nástrojom d16, z4, ap=15, ae=3, F1000.
toto by podľa mňa "dospelá mašina" mala bez problémov zvládnuť.
Keď som dal nový nástroj, tak to aj zvládla, ale po určitom otupení sa začal motor preťažovať.
chybu to vypisuje najčastejšie: F304 motor foldback.
Pri spadnutí do chyby som skúsil teplotu motoru, dá sa na ňom udržať ruka. Motor na X bol úplne studený.
otázky:
1. je normálne, že pri tomto zaťažení motor preťaží?
2. vie mi niekto poradiť ako ešte lepšie nastaviť menič, aby to makalo?
3. ako (na aký pin) pripojiť signál z meniču, že všetko je OK? Chcem aby v prípade preťaženia stroj zastal na ďalej nek...l obrobok. Signál ENABLE nemôžem použiť, leb by to vyplo ostatné pohony, a "Z" pri vypnutí klesne o cca 1-2mm a nabúral by nástroj.
