Rozchodim to ?
el_fuego333
5. 4. 2010, 11:46
Zdravim,
mam AC servo motory s takouto charakteristikou:
48V, 200W, 6.4 A, 18 A peak, resistancia 0.6, intuktancia 1.7
a drivery s takouto charakteristikou:
INPUT: 115/230, 3 Phase, 6.5 A/phase, 0.88-1.4 KVA
OUTPUT: 115/230, 3 A/phase, 0.7-1.1 KVA
Bude sa to dat nejako rozchodit, resp upravit voltaz pre motory na 48V ?
Vdaka za akukolvek informaciu.
Andrej
PBr
Chodit to mozno bude, ale nie na plny vykon, kedze menic nie je schopny dodat trvaly prud 6.4A. Pravdepodobne bude vypinat nadprudova ochrana.
el_fuego333
6. 4. 2010, 8:32
zda sa, ze mam eroticke ruky...
prichy
6. 4. 2010, 5:15
proc? stoji ti vsechny motory jo? :lol: :lol: :lol:
Prichy
el_fuego333
6. 4. 2010, 6:54
prichy píše:proc? stoji ti vsechny motory jo? :lol: :lol: :lol:
Nieco lepsie.. Coho sa chytim, to doje**m.
PBr
Co to bolo tentoraz? :)
el_fuego333
7. 4. 2010, 10:03
Pomozete mi vybrat ?
Mam zakupene serva na 18V, 6.5A / 18A peak, encodery s 2000 lines (8000 counts).
Na vyber mam drivery bud:
1. analogove s prebytkom vykonu 12A / 20A peak
alebo
2. digitalne s nedostatkom vykonu pre motor 5A / 15A peak
presnejsie udaje:
Single-axis, operating in stand-alone or slave mode (distributed intelligence)
Control modes: position, speed, torque, voltage, external variable
Motion modes: profiling, contouring, pulse & direction, electronic gearing
Programmable protections: overcurrent, over and under voltage, I2t
Output current: 5A (5x models) / 8A (8x models) continuous; 15A peak
Supply voltage: 12 to 48 V DC
Compact covered-frame design (136 x 84.5 x 26) mm
DSP controller technology. Based on Technosoft MotionChipTM
10-bit PWM @ 20KHz
RS-232 or RS-485 serial communication, up to 115 k baud rate
Operation in multiple-axis structures, via the RS-485 communication channel
Prosim poradte, ktory driver je lepsi k danemu motoru.
Bude to urcene najma na precizne obrabanie tvrdych kovov - precizne 3d obrabanie - pomale rychlosti, 5-osa masina.
Potrebujem to riadit tak, aby som dokazal urobit precizne priestorovu krivku - pri pohybe vsetkych os sa urobi jeden krok, encodery posielaju impulzy priamo do PC, ked prebehne krok na vsetkych osach, ide na dalsi krok. Ked sa opozdi niektora osa, cakaju vsetky osi..
Dakujem Vam.
Zpět na „Servomotory“
