4 osa gravírovací CNC frézka 3020T - prodano
deje
5. 5. 2015, 5:40
jenom odzkoušeny. manželka rika: ne patri do obyvaku )
je mozne za priplatek 4000 Kc pridat 400w vreteno se zdrojem.
vzadu je prasknute plastove ulozeni kabelu a nepatrne ohnuty roh.
zdarma pridam par hlinikovych desticek 6063
predvedu v praci
lokalita: Praha
cena: 23 900 Kc
specifikace:
3020T triaxial engraving machine part parameters:
Effective working travel:200(X)mm*300(Y)mm*50(Z)mm
Shape dimension:550x400*350mm
Max.workpiece dimension:200mm*300mm<65mm
Work table dimension:200mm*300mm*15mm
Frame materials:aluminum alloy 6063 and 6061
Driving units X axis:1204 trapezoidal screws
Driving units Y axis:1204 trapezoidal screws
Driving units Z axis:1204 trapezoidal screws
Sliding units X axis:Dia.13mm chrome plate shafts
Sliding units Yaxis:Dia.16mm chrome plate shafts
Sliding units Z axis:Dia.12mm chrome plate shafts
Stepping motor type:57 two-phase 1.45A-2A
Spindle motor:200w dc motor
Principal axis collet:ER11/3.175 mm
Spindle speed:300 ~ 8000rpm/min (PWM stepless speed regulation)
Repeat accuracy:0.05mm
Empty line speed:0-2500mm/min (16 subdivided driving down)
Spindle precision:radial beat acuities 0.03 mm
Control unit:triaxial one-piece drive + ring variable power + PWM speed
Carving Instructions:G code/TAB files/nc file/NCC files
Communication interface:through parallel connection with computer
Software environment:Windows 2000 / xp
Carving speed:0-2000mm/min (different materials differ)
Machine weight:24KG
obsah:
1× Engraving machine
1× Control box
1× Parallel cable
1× Power cable
1× Tool box and tools
4× Axis motors
Naposledy upravil(a) deje dne 26. 6. 2015, 12:26, celkem upraveno 2 x.
Tak ti nevím ,a nebylo by lepší dát sem fotku manželky s cenou podle pravidel fora :wink: a frézku si nechat :lol: :lol: frézka ti nebude mluvit do toho co patří do obyváku :lol:
slovojar
24. 6. 2015, 3:38
Tá štvrtá os je zapojená a používali ste ju ?
Slava A123
24. 6. 2015, 5:20
Dobrý den, můžu si jí rezervovat do zítřka, manželka se vrátí cca v23.00 tak to nemohu hned rozhodnut :(
deje
24. 6. 2015, 7:51
slovojar píše:Tá štvrtá os je zapojená a používali ste ju ?
ani ne zkousel jsem tu 4 osu, ale samozrejme pred koupi da se pripojit
kovoel
25. 6. 2015, 2:49
:roll:
V20
