num 1060 software
Juro
11. 12. 2019, 8:17
Toto v pocitaci mas spravne nastavene?
hanz100
11. 12. 2019, 4:53
jo mam koukal sem na to nastaveni a menil podle navodu co je pdf vubec nic me to nedela
Dawe
11. 12. 2019, 4:55
Ja vim zes to urcite kontroloval, ale nejcasteji za to muze kabel. Tady musi byt plne obsazeny, propiskej pin po pinu multimetrem.
hanz100
11. 12. 2019, 4:59
13.1.2 Configuring the Port for the NUMCOM Software
NUMCOM is a public domain programme relatively widespread among NUM CNC users. It runs under DOS. It is used
to upload and download files via a serial interface. Other applications, such as NUMPC, are available from the NUM
network.
In order for NUMCOM to operate correctly, set the port as follows:
Line Number Free choice; see Sec. 13.1.
Standard RS232
Input Speed (Bds) 9600
Output Speed (Bds) 9600
Number of start bits 1
Number of data bits 8
Number of stop bits 1
Parity None
Protocol None
Flow Control RTS/CTS
Logical Name Free choice, but COMM1 is recommended
Configuration x/12 Accept
13.1.3 Selecting an Existing Configuration
hanz100
11. 12. 2019, 5:00
kabel sem sam delal nemel sem krizovej tak sem ho daval dohromady podle tohodle
hanz100
11. 12. 2019, 5:02
kabel
us_112_RS232_Cables.zip
(56.67 KiB) Staženo 1155 x
Dawe
11. 12. 2019, 5:05
A mas to fakt dobre? Zkontroluj si to pin po pinu. RTS/CTS je taky krizene a protoze je na nich zavisly timing te seriove komunikace, tak to bez nich nepojede.
Naposledy upravil(a) Dawe dne 11. 12. 2019, 5:06, celkem upraveno 1 x.
hanz100
11. 12. 2019, 5:05
uz si nejak nevim rady nechtel sem to nejak degradovat tovarni kvalitu masiny ale asi do ni koupim kartu mesa a predelam to s boží pomoci :roll:
hanz100
11. 12. 2019, 5:07
jdu se jeste na to mrknout
hanz100
11. 12. 2019, 5:10
krizil sem pin 2 s3 a pin 7 s 8 pin 5 zustal na stejnu
Dawe
11. 12. 2019, 5:21
A popropojovane piny 1,4,6,9 na PC strane mas?
Jestli pouzivas USB na RS-232 konvertor, tak zkus jiny, nebo lepe starsi PC primo s hw portem.
Jestli pouzivas 9pin->25pin redukci, tak ji propiskej, nebyvaji casto zapojene komplet.
filla
11. 12. 2019, 5:29
jestli se ten sw pokousis spoustet na win7 a vyssi, tak to fungovat opravdu nebude, bude to chtit idealne w95/98, mozna to jeste pujde na xp
11. 12. 2019, 5:36
filla píše: 11. 12. 2019, 5:29 jestli se ten sw pokousis spoustet na win7 a vyssi, tak to fungovat opravdu nebude, bude to chtit idealne w95/98, mozna to jeste pujde na xp
To víš nebo si to myslíš?
Obsluha sériových portů se většinu dělá (a dělala i dávno) pomocí služeb BIOSu a OS, nikoli přímým přístupem do registrů. Takže i starý DOSový program na COM by mohl fungovat.
Ten, co je v tom vlákně na CNCzone, je dokonce Windowsový, i když taky hodně historický.
Ale když tazatel není ani schopen/ochoten napsat co mu to dělá a co mu tedy vlastně nejede, tak to je pak těžké.
No ale každý svého štěstí strojvedoucím.
filla
11. 12. 2019, 5:40
nekolikrat jsem se s tim setkal a navic to nefunguje s levnymi usb>serial, pokud potrebujes vic jak rx/tx/gnd
11. 12. 2019, 8:47
filla píše: 11. 12. 2019, 5:40 nekolikrat jsem se s tim setkal a navic to nefunguje s levnymi usb>serial, pokud potrebujes vic jak rx/tx/gnd
Svatá pravda, proto skovávám starou IBM s com1 a win98 přesně na takovéhle špeky.
Jestli chceš půjčit, můžu ale jen osobně tam i zpět.
Zpět na „CNC soustruhy“
