asi vadny firmware pro mesa 7i92, poradi nekdo?
jaro.va
ucf subor -to asi nebude co hladas
PIN_7I77_7I76_34 tam je zaujimave, ze 2-x sserial ma rovnake oznacenie (adresa ?) 00
- Přílohy
- 7i92ucf.txt
- (6.55 KiB) Staženo 192 x
- PIN_7I77_7I76_34.txt
- (9.81 KiB) Staženo 195 x
no to prave asi bude ten problem
protoze tam maji byt tri nebo dokonce 4 kanaly ted nevim jiste
ale 7i77 ma jeden kanal na analog out a dalsi na IO piny a pak je tam jeste jeden sserial ven na dalsi zarizeni
jaro.va
niekde na linux fore som zachytil, ze treba premenovat sserial kanaly ....
muzu te poprosit ze by jsi zkusil si s tim pohrat?
jaro.va
jaro.va
inak som pozeral tvoju konfiguraciu v PNCCONFIG a ma to iba 1 serial
(a 2 kanaly.. neviem ako to mysleli) sserial_port_0=21xxxxxx The first digit (2) selects the software mode from the 7i76e itself,The second digit (1) selects the software mode of the connected SSerial device
cize skus konfigurovat v PNCConfig ..
ten sserial na 21xxx jsem uz zkousel driv
ve vypisu linuxcnc je toto:
hm2_eth: discovered 7I92T
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): IOPort
hm2/hm2_7i92.0: IO Pin 005 (P2-16): IOPort
hm2/hm2_7i92.0: IO Pin 006 (P2-04): IOPort
hm2/hm2_7i92.0: IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0: IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
potom je tu vypis mesaflash readhmid:
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 64 bytes
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Instance Stride: 4 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P1
1 17 IOPort StepGen 0 Dir/Table2 (Out)
14 18 IOPort StepGen 0 Step/Table1 (Out)
2 19 IOPort StepGen 1 Dir/Table2 (Out)
15 20 IOPort StepGen 1 Step/Table1 (Out)
3 21 IOPort StepGen 2 Dir/Table2 (Out)
16 22 IOPort StepGen 2 Step/Table1 (Out)
4 23 IOPort StepGen 3 Dir/Table2 (Out)
17 24 IOPort StepGen 3 Step/Table1 (Out)
5 25 IOPort StepGen 4 Dir/Table2 (Out)
6 26 IOPort StepGen 4 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort MuxedQCount 3 MuxQ-IDX (In)
12 32 IOPort MuxedQCount 3 MuxQ-B (In)
13 33 IOPort MuxedQCount 3 MuxQ-A (In)
prijde mi to ze se nedeje spravne detekce toho slave
hadam chybu ve firmware protoze samostatne s jinym firmwarem to jede
ale muze to byt cokoli
nemuzu najit seriozni popis toho konfiguracniho registru pro sserial
edit:
ted jsem si s tim hral a jakoby na ten registr nereagoval
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
edit:
jaro.va
ja tu kartu 7i92 nepoznam, ale v manuali je :
7I77_7I76D is a configuration intended to work with
a 7I77 six axis analog servodaughtercard on P2
a 7I76 daughtercard on P1
ak su tie P1,P2 identicke, ci ich nemas prehodene...
karty mam dle popisku spravne
a kdyz je na zkousku prohodim tak to nefunguje uz vubec tj. nenajde to sserial ani na te 7i76 karte
coz predtim naslo
edit
nasel jsem:
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=6 num_pwmgens=0 num_stepgens=5 sserial_port_0=00000001 sserial_port_1=00000001"
This will enable all features of both the 7i77 and 7i76 cards.
po tomto to ale napise tohle:
hm2/hm2_7i92.0: num_sserials references 2 instances, but only 1 are available, not loading driver
hm2/hm2_7i92.0: failed to parse Module Descriptor 5
board fails HM2 registration
coz predtim naslo
edit
nasel jsem:
jaro.va
to je uz radostnejsie
po zadani nazvu chyb to vyhodi 2 linky na forum linuxcnc - ale tomu ja nerozumiem
mne utkvelo v pamati ze vzdy pouzivat afresu 10.10.10.10
ip adresa s tim nesouvisi
komunikaci tam mame jasne zivou
jaro.va
podarilo sa ti to vyriesit ?
ne
zatim nic
asi budu muset zajit na anglicke forum
zatim nic
tak mame rozuzleni
pri vsech tech testech jsem vyzkousel vsechny mozne kombinace
prehraval jsem si to dnes v hlave a zjistil jsem ze si nejsem jisty prohozenim kabelu
novy kabel potvrdil ze ty kombinace nebyli uplne vsechny. Bylo to prave v tom jednom kabelu.
Normalne krimpovany na plochou ksandu a je vadny.
kazdopadne dekuji vsem za podnety
